Numbers Tomorrow, any guesses?
I will be dyno'ing on a dynojet tomorrow making 3 pulls. One on motor and two on spray. Anyone want to predict numbers?
Humidity should be fairly low, temps in the low 50's - 60* at the time.
Mods include:
Full bolt'ons -minus water pump, and UD pulley
Custom true duals dumped pre-axle with cherrybomb single chambers
Comp Cams 224/224 .581/.581 112LSA
Stock 10 bolt with GM 4.10's
Mods include:
Run number 3 was a 3rd gear motor pull. The first time I dyno'ed my car (2 year ago) on a mustang dyno it made 330ish untuned with a cam in 4th gear. The owner of the dyno told me to try a pull in 3rd gear to see if it makes a difference. It was 18hp higher in 3rd than it was in 4th. I tried a 3rd gear pull on motor to see if anything different would happen this time, and as you can see, lower.
For the first time on a dyno. I've been spraying this car for about a year.
It will break Mickey Tompson 275 Drag Radials loose from a 3rd gear roll at 50mph even though its progressed. Its pretty fun. It just made me more power hungry though.
