View Poll Results: How much power you got?
Voters: 77. You may not vote on this poll
How much RWHP you pushing?
Got 408 RWHP.
My LS-7 clutch and 3.91 gear set are eating about 7-8 RWHP.
I have a Street Sweeper cam, Kooks 1 7/8 long tube headers, Corsa sport catback, Power Bond under drive pully, electric water pump with a 170* thermostat, a FAST 78mm throttle body mounted on the stock un ported LS-6 intake, a K&N drop in panel filter, and a bad tune with stock plugs.
Put on an LPE CAI in between.
Currently, I have NGK TR-55 plugs, milled and mildly ported ETP 215's, longer 8.1 pushrods, new high RPM lifters, FAST 92 mm throttle body and intake (both being ported with the heads), a Spec 3+ clutch with aluminum flywheel all going in within a few weeks.
That should net me above 460 RWHP.
At this moment, I am running 12.40's at 114 mph on a 2.10 60' and M/T 275 drag radials. Wheel spin like a Mo Fo in first. Going for mid to high 11's with the new setup and 16" 26x10.5-16" E/T streets.
05 Torrid Red M6
K&N cai Kook's 1 3/4" LT's catted mids & Borla, Polished Maggie 112, cam kit, SCSS triple pillar pod with matching GTO boost & FP & WB gauges.
528 RWHP 497 Torque. Ran that for 1500 miles.
Currently have a new motor being built:
New GM aluminum block Stroked forged 402
Diamond -10 relief pistons
ETP 225 66cc heads with Scorpion rockers
DM Performance main girdle
Topped off with a Magnusun 122 OVERDRIVEN w/ 60LB injectors and a 3.1 snout pulley
Changing up to Kook's 1 7/8 coatted headers
Adding lot's of drivetrain pieces, and Wildwood Big Brake kit.
Looking for 615 rwhp and 700 torque
Tom
Tom
2004 (6M), 383 RWHP. Kooks 1 3/4" LT's, Powerbond UD Pulley, F13 Cam and Futral Tuned. I'm doing suspension mods this summer. Then maybe an intake and throttle body to get me to the 400 mark.
With my 408 RWHP, I have hit a 12.5xx at 113 MPH. And that was with an ugly 2.01 60' and the bad tune. With traction, I know I'm very low 12's and 114+ MPH.
With the new heads and intake with the other mods in my above post. I am sure to see high to mid/high 11's.
