Running Lean Up Top Bad!
Car is running 14.6 A/F after 4400 rpms. We dumped as much fuel as we can with edit. But cannot get the A/F richer. Down low its rich, but up top lean. We thought it was the injectors(stock 99s). So we swapped to 30lb SVO. Still the same problem. Under 4400 rpm got it to 12.5 A/F but over 4400 cant get it under 14.6. This is with the cutouts closed running through SLP Dual/Dual. Anyone have any insite on this. Here is the break down of the car.
99 Camaro SS
Stage 2 Heads 2.02/1.57
226/230 .574/.575 112 Lunati Cam
1 3/4 QTP Merge Collector Heads
3" QTP Y Pipe
SLP Dual/Dual
4.11 12 Bolt
LS6 Intake
LS1 Edit Tuned
Any input is most appreciated
99 Camaro SS
3" QTP Y Pipe
SLP Dual/Dual
4.11 12 Bolt
LS6 Intake
LS1 Edit Tuned
Re: Running Lean Up Top Bad!
Fuel pressure isn't dropping at WOT when you go lean? If not the fuel pump is fine. What are injector DC looking like? What does the MAF do when you are going up - does it flatline or does it continue to increase?
Fuel filter maybe?
Also log the injector pulsewidth. Maybe that will give a clue. Ex. if the pulse is very long and it is still not getting fuel, then there is some pressure problem. If pulse is short, then the computer is not keeping the injectors open long enough...
Good luck.
Tommy
Good luck.
Tommy
A couple things to try....
1) Reset the PCM. Unplug it and let it sit. We had this happen once and resetting the PCM did the trick.
2) Keep the car in open loop (just for a trial run)
3) Start over. Load your original stock program and start over if the problem persists. It sounds like a program problem.
