Where to tap power for nitrous...
To do it you need to run a relay directly off the battery since the solenoids pull alot of current. I would suggest running the entire system including the arming switch off the battery as an independant system and make sure you use fuses as well. I have seen people run the controls off the radio fuse but I just find that as the easy way out.
