supercharging a stock 99 z28
i have a stock engine on my 99 z28 and i got a really good deal on a vortech supercharger and couldn't pass it up, its the entire kit braand new for $3,000. i don't have the money for other mods. so my questio is would it be alright to install the supercharger or do i need to wait until i have other mods first nd if so which ones?
It's really up to you. I got a really good deal on my Vortech G trim and only had a lid and catback on my otherwise stock TA. I just finished installing it and couldn't be happier. It's all about risk....running boost hightens the potential for things to break. EX: motor, rear end, etc. Can you still run the blower on your lightly modded car? Absolutely....you just won't be making as much power as those who have stroked forged motors and won't have the peace of mind of those with the right supporting mods. Either way you go, good luck.
Btw, what kind of Vortech kit did you get?
This list I put together may help you out. Bob
http://www.exoticperformanceplus.com....html?item=540
http://www.streetlegaltv.com/index.p...flv&playlist=1
1000hp at the crank, holy ****
stock crank too... holy ****.
thats amazing, that guy definitely knows whats going on and has the money to make it happen.
Don't the vortech kits come with a fuel pump? The only other thing you would need is some larger injectors. I wouldn't turn the boost on the stock short block above 8-9 psi anyways.
"Check out this video with Kevin Polchion being interviewed, who has a 1998 Trans-Am that has an ATI ProCharger D-1SC on a 346 ci engine. Kevin has run a 9.13 at 149.50 mph so far!"
