driver side back noise helpp
I have a 02 trans am that everytime i go over bumps theres a popping/ rattling noise coming from the left weel area sometimes sounds like its just under the drive side area ... i replaced the shocks thinking it was that and checked all the bolts to see if anything was loose but cant find anything and noise is still there...someone help?....any ideas??
Is the car stock, any suspension mods, besides the shocks? Have you checked the rear torque arm bolts? If you're sure it's coming from the driver side, you should check the lca bolts, if you haven't already.
i replaced the shocks thinking it was that but nothing, it is stock except slp exaust and air box.... i put the car up on the lift and tightened every bolt i saw and nothing... any other ideas
