Is there a cross-over ujoint for the ACPT driveshaft ??
Like the subject says. I got my new Strange 12-bolt, and found that the cross-ver u-joint they sent will fit the stock aluminum driveshaft, but it is too big to fit in the ACPT CF driveshaft that I have, and was planning on using.
Re: Is there a cross-over ujoint for the ACPT driveshaft ??
are you sure? I got a xover u with my strange, to go from a 1310 (shaft) to a 1350 (yolk). the regular acpt uses 1310's, at least mine did. assume your strange has the 1350 yolk.
I ended up going to a denny's shaft (1350) so never used the xover but it measured up ok.
