Aftermarket tranny cooler lines....
Hello, well im looking to move my trans cooler to the rear of the car with a fan or lip on it for air. So with this i want to run new tranny lines to it.... What kind and sizes are you guys using? What type of fittings are needed to mount these lines to the 4l60-e since i know the stock set up is very weird. Thanks!
-Jon
-Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
From another thread:
1/4" and 6AN X 2 (transmission fittings)
45 degree 6AN snaplock fittings X2 (you would use the 6AN fittings for braided hose)
90 degree 6AN snaplock fittings to go on the trans cooler
1/2" Npt and 6AN X2 to go into my trans cooler
X amount of -6 braided line to and from the transmission
Thank you! Are you sure the tranny fittings are 1/4" though? All the stuff on this car is metric. If someone can verify the fitting on the trans that would be perfect! Thanks
__________________
Also... if it is 1/4, is it reg 1/4 or 1/4 NPT? Thanks!
__________________
