Generation IV Internal Engine - other then Assembly Lube , is there any way to !!!
BadLtBlu99TA
03-23-2008, 07:34 PM
other then using assembly lube , is there any way to run oil around in the engine , as it would normally run when the engine is running ?
427
03-23-2008, 09:32 PM
You can do it with a external pump connected to the oil galley.
Kurt
BadLtBlu99TA
03-23-2008, 09:33 PM
where could i buy an external pump at ? this would be really handy ..
racecar
03-23-2008, 11:45 PM
I have an Accusump that hold 3 quarts of oil. It's great to pre-lube the engine before starting.
427
03-24-2008, 10:58 AM
The one I use is a Weldon oil pump. It won't run more than about 15 minutes with pressure (gets hot), but it sends oil all through the engine in that time.
Kurtwhere could i buy an external pump at ? this would be really handy ..
BadLtBlu99TA
03-24-2008, 04:42 PM
do youguys have picture or part #'s for this stuff ?
427
03-24-2008, 09:25 PM
Mine is a Weldon 9200-A, it is used to pump diff fluid or trans oil to coolers in a road race car. I use it with a -6 to power steering adapter which is 14mm like our oil galley plugs, just put a -6 o-ring over the threads on the power steering adapter and screw it into the side of the block up by the pump.
Kurt
