z28berryhill
03-23-2008, 09:49 PM
whats the diff between the two and how can i get it to work???
jmm98LS1
03-24-2008, 04:42 PM
The '98 cluster is not interchangeable with 99+. You need a '98 cluster for a '98 car....no way around it. A 99+ cluster will not work in your car.
RE AND CHERYL
03-25-2008, 07:05 PM
The 98 cluster is basically a 97 cluster with a different tach and the fuel gauge works on a different resistance value. The main difference with the 99 up cars is the cluster gets a signal for most everything through a single serial data wire.
The 97 and 98 clusters are single year pieces and don't interchange.
Re'
