Rear control arm bolt size?
Old 03-24-2008, 08:08 AM
WhiteRabbit22's Avatar
Default Rear control arm bolt size?
I'm trying to get my subframe connectors installed, however the rear bolt i have for the control arm isn't long enough, and I need a longer one. Can anyone tell me the size of it? I can't take it up to Home Depot because I only have this car, and running without a control arm bolted up would be a bad thing, lol.
Old 03-24-2008, 08:18 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
12mmx110mm will fix you up........
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 03-24-2008, 04:20 PM
Thank you!
Old 03-25-2008, 02:53 PM
Major_Lee_Slow's Avatar
Make sure you get a good bolt that has a 10.8 marking on the head. It there is no marking you'll have no idea of the bolts strength. I've found that bolts at ace hardware tend to be better than the bolts at Home Depot.
