Who has this cam 228/236 115? what does 115 mean?
Old 03-24-2008, 12:05 PM
DaDon357's Avatar
Default Who has this cam 228/236 115? what does 115 mean?
I plan on putting this cam into my car but i don't know what this means. Where will it make its power and how does it idle?
Old 03-24-2008, 12:12 PM
zaner's Avatar
115 lsa will idle smooth but will make peak power a lil higherthan a 112 in the rpm band...its not a cam id put in my daily driver cuz i like a lil more usuable power and hate spinning a stock bottom end to 6500 to go fast...
Old 03-24-2008, 12:13 PM
COD02SS's Avatar
http://www.chevyhiperformance.com/te...ics/index.html
BTW - I'm thinking about using a cam like that in my SS
Old 03-24-2008, 12:18 PM
DaDon357's Avatar
what do you mean by usable power? I would have to spin my bottom end fast in order to go fast. I would like to mention it is going into a lq4 with L92 heads unported and unmilled witha l76 intake.
Old 03-24-2008, 06:04 PM
hammertime's Avatar
*** CAM GUIDE ***
In a nutshell 115* is the lobe separation angle, or the distance between Exhaust Closing and Intake Opening. 115 is a on the wide side, depending on where you want you power to peak. It will have just 2 degrees of overlap, so it should idle rather smooth, especially in a 6.0L.
You may be better off defining your entire setup and asking for a cam recommendation. That cam is a good first stab for an L92 head combo, but I'd look for 113* LSA and install it 2* advanced to bring the power peak down over what you listed initially.
Old 03-24-2008, 10:34 PM
DaDon357's Avatar
The combo is a lq4 stock block, with l92 unported unmilled heads and a l76 intake, stock rockers, stock lifters, stock oil pump, stock rods, headers from street and performance and the cam above. Im looking or hoping to make around 440-460 to the wheels and i would like to know if it maybe achievable with this setup with a 4l60e behind it.
Old 03-24-2008, 10:57 PM
2002t/a06's Avatar
in my opinion it will be tough to achieve 440-460 with unported heads and that cam through a stalled 4l60e.
Old 03-24-2008, 11:35 PM
Gregorya24's Avatar
mti g1 is a 228/230 with a 113 lsa you should look into that cam!
Old 03-25-2008, 12:25 AM
hammertime's Avatar
I don't think that the stock LQ4 bottom end is going to help you. You're going to need some compression to make that work, at least 11.0 on that wide LSA, but you could tolerate even more.
You might make those numbers through an M6, but not a 4L60. If you want 460 though an A4, put a 4" crank in there to make it a 402-408.
Old 03-25-2008, 04:46 AM
odarabla's Avatar
The 115 is the lobe separation of the cam.. With a 115LSA it should have a some what smooth idle. I have a 114LSA cam. click on the link below if you wana here what it sounds like.
Old 03-25-2008, 07:39 AM
Old SStroker's Avatar
There is some misinformation posted here.
The 228° is the intake duration in crankshaft degrees, and the 236° is the exhaust duration in crankshaft degrees. Both of these are measured at .050 lift of the tappet (lifter). Since the cam turns at 1/2 the crankshaft rpm, the actual rise on the cam lobe uses less than 180° of the total lobe. At .050 lift, it is actually 114 camshaft degrees and 118 camshaft degrees.
The 115 is the Lobe Centerline Angle or commonly Lobe Separation Angle, which is the angle between the centerline of the intake lobe and the centerline of the exhaust lobe measured in camshaft degrees. This is the only camshaft parameter measured in camshaft degrees.
As to what results you will get from that cam, I'll leave that to others because I don't know enough about your vehicle/engine combination to tell.
Here's a pic from Comp Cams catalog.
Old 03-25-2008, 05:57 PM
DaDon357's Avatar
So to make it 402, all I need is a 4" stroke. How do I achieve this and is there anything else needed to be changed?
Old 03-25-2008, 05:58 PM
DaDon357's Avatar
what kind of mufflers do you have?
Old 03-25-2008, 06:01 PM
COD02SS's Avatar
Thank You sean connery
Old 03-25-2008, 06:43 PM
Bader-X's Avatar
to make it a 402 or 408 you`ll need new pistons that is designed for the new crankshaft Stroke and and new piston rings if you choose 408 (Bored engine block).
Old 03-25-2008, 07:00 PM
iI you meant the avatar pic, that's really Burt Reynolds who played Stroker Ace in the movie. People often mistake us for brothers...........NOT!
Jon
Old 03-25-2008, 07:05 PM
DaDon357's Avatar
So with a 402, I don't need to bore the block, just new pistons and crank? if so where can i get this?
Quick Reply: Who has this cam 228/236 115? what does 115 mean?
