water - a/c problem (help)
Old 03-24-2008, 05:17 PM
00badfnta's Avatar
Default water - a/c problem (help)
Does anybody know where the ac hose drain is at? Picture would help too. I keep on getting woter on my passenger side floor board. It not the t tops or the cowl pan. I ran water throught the top throught the cowl pan. I think it might be the ac drain hose but I dont know where it is. Its not all the time it rains its gets wet just sometimes. If anybody have any ideas on the problem or where the a/c hose is please let me know.
Old 03-24-2008, 06:06 PM
2001NBMZ28's Avatar
AC condensate drain? Should only leak with the AC/defrost on. http://shbox.com/1/a_c_drain.jpg Ours is similar.
Old 03-25-2008, 12:26 AM
00badfnta's Avatar
It doesnt leak all the time thats the problem. I think its the a/c, I think the a/c gets backed up and then leaks out later when i'm not in the car. Do you have better picture than that.
Old 03-25-2008, 12:50 AM
ae13291's Avatar
that looks like a clear picture to me! im thinking its your heater core
Old 03-26-2008, 05:35 PM
00badfnta's Avatar
If its my heater core where is it and how do I stop it from leaking?
Old 03-26-2008, 06:47 PM
ae13291's Avatar
it is under the passenger side dashboard! there should be a big heater box that heater core is in. or follow the 2 heater core lines that are connected to the waterpump right by the thermostat! for a temparary fix you can bypass those 2 lines
Old 03-27-2008, 01:54 PM
2001NBMZ28's Avatar
If the water is clear and odorless I'd try carefully sticking something like a pipe cleaner into the AC drain. If it's dexcool leaking then probably the heater core.
Old 03-27-2008, 03:55 PM
00badfnta's Avatar
i'm pretty sure its plane water.
Old 12-03-2008, 06:54 AM
LANDONZ's Avatar
i know im bringing this back from the dead, but I actually woke up yesterday morning and my floorboard was full of water.. It didnt rain nor did I run the A/C at all.. Possible leaking somewhere? anybody had that problem
Old 12-11-2008, 07:30 PM
jsteele90's Avatar
heater core for sure
