Dart heads + TRAK cam
So i was thinking about buying the TRAK cam and then getting a set of Dart heads milled n P/p and intake matched. I also just got a fast 90/90 to go on.. .so think this would be a good set up?? or get a different cam to do this with?? G5X3?? What kind of power you think this set up would make??
Thanks
Derek
Thanks
Derek
Doesnt seem like a good match as the high lift of that cam is out of the powerband of the dart heads. Those heads would better match a Cheater cam, F13, 228r cam imho. I think the Trak would be better suited to a stage 2 Livernois head or tfs 215s where the higher lift of the cam would match the highflow those heads offer over .600 lift.
Just read your post again and for some reason thought it said 205 darts. Yes I think the 225s would be a good match. Look at this post. Almost the same cam.
https://ls1tech.com/forums/dynamometer-results-comparisons/615147-f14-highlift-dart-225-heads-numbers-inside.html
yeah i was thinking about getting the livernois stage 2 heads cause of the group purchase... just waiting on the machine shop to let me know how much it would cost for the heads n all the machining... i probly should add i have a yank ss4000 3.73 gears LT ORY and SLP LM1 exhuast
