Nitrous Oxide - timing ???
texasheat
03-24-2008, 11:27 PM
I'm currently running 26 degrees with mods in sig and a 100 shot. Plugs look good and had it checked with hp tuners or efi live (one of those) and there was no knock. I'm thinking od going ahead with the 150 pills...how much more timing should I ull for the 150? Would 2 more degrees be sufficient or should I pull three to be safer?
Johnnystock
03-25-2008, 09:19 PM
its usually 2deg per 50hp of NOS..I'll pull 5 on my 125pill
madclown
03-25-2008, 11:11 PM
I think to be safe you should have a wideband or have it on the dyno to watch the A/F Ratio..... My car is running out of fuel press. on the 100 shot after the cam and bolt-ons......
texasheat
03-26-2008, 12:00 AM
I have a fuel pump and wideband with the lean shutdown switch
ScramingYellowZonker
03-26-2008, 12:03 AM
3 would be safe. personally I would pull 4. It is better to be slow than to get a tow home.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
