What should i get my yank 3600ss to lock up at???
Just what the title states????
i know it will be around 35-38 on stock tune but how will it be with the mods in my sig.... i dont have my car tuned for anything in my sig yet,still wating to get everything installed.
What mph do guys think would be the best?????
First you need to make sure the PCM is adjusted for the 3.73 gears. Generally the stock lockup points are too low for a big stall and can be bumped up by about 5 mph. However, the actual shift points are really dependent on your actual setup and driving habits/preferences.
for a rough guess
Mine is similar (slightly higher), but the lockup mph varies by a couple of mph depending on the TPS %. I would think with a 3600 he should be able to still use 3rd gear lockup.
My converter had clutch chatter when it locked up at 38, 40, and currently 42 mph.
I've tried two different tuners and used three different mph's and I still have a little clutch chatter.
