Valve to piston Check????
Brad hit it on the head. If you are looking for an equation to figure it out, there isnt one, too many variables for a consistant equation. I just got educated in this matter. The clay is the way to go.
clay is probably best, but if you're just wanting to see if you have a certain amount of clearance, you can put feeler gauges of that thickness between rocker tip and valve...that won't tell you exactly how much you have tho.
