Vid from Atco rental Monday 3/24
Second time out with the car, Track was hookin real good!!
02 Z28 3400# race weight
408 Th400 12 bolt w 4.10's
10.09 @ 134 1.419 60 ft.
Here is the Vid:
url=http://fastlsx.vidiac.com/video/741760ef-c633-44a3-8cc1-9a6a016bc787.htm][/url]Click here to see Video
Here is the Vid:
I have a Select 5000 conv.
I have QA1's adj shocks all around, PA K-member, Spohn upper & lower control arms, spohn chassis mount T/A. Spohn drag bar stock rear springs,
Adj rear LCA's & Panhard bar,
Simple set-up & I can drive the car anywhere!!
John
Thanks for the info. You have a very nice setup and eventually think I might go to a similar setup. I'm thinking of a 4400 stall eventually, just trying to figure what the best tranny setup will be. Currently the car is a six speed and probably stay that way for the next couple years. Long term plan on making this a low 9 sec street car. Thanks for the info, Fred
i think a spool with 4.30's may do the trick.. and the car is a pig 3400# with me in it.
