1990 Camaro Iroc - starts then instantly stalls
I'm helping my father-in-law diagnose an issue with his car. It's a 1990 Iroc Camaro with the 305. Manual trans.
Here's the issue - you start the car, it'll run for about 2 - 5 seconds, then stall. You restart it, it runs for 2 - 5 seconds, then stall. It'll go through this routine 8 - 12 times before it will actually stay running so you can drive it. It's not starved for gas. Electirically it seems to be being shut down.
Anyone have any tips or tricks to try? My initial thought is a faulty sensor on the throttle body. There is no check engine light, by the way.
Does the car set any codes?
