TH350 w/stock torque arm
Old 03-26-2008, 11:16 AM
Stroked96Bowtie's Avatar
Default TH350 w/stock torque arm
Im doing a TH350 conversion, has anyone had any luck doing this with a BMR crossmember keeping the stock torque arm? Im running a moser 12bolt rear and has the 4 shorter bolts, not the all the way through type like a 9in or stock 10bolt, that fastens the TA to the rearend. Is that a problem if I use the BMR crossmember?
Thanks for any info!!
Old 03-26-2008, 11:22 AM
dlove's Avatar
read my faq
Old 03-26-2008, 11:57 AM
Torque Arm-
The th400 will not have provisions for a TA. You have 2 options.
1. Stock mounted TA
2. Chassis mounted TA
Spohn, Madman, BMR, UMI, etc.
Yes I have a few times, its been very helpful. So it looks like you can use the stock mounted torque arm. I called around this morning and BMR makes one with a TA provision so I can keep the stock TA in place.
