Anyone have a problem with a bog down in 3rd gear from a 30 roll?
I have a 99 t/a 4a and it bogs down real bad in 3rd gear from 30 mph and I cant get the god forsaken thing to unlock. The only way I can is to gun it but then it kicks down to the passing gear. Anyone else have this problem short of taking the trans out and putting a new stall in.
Thanks
Matt
Thanks
Matt
LS1Tech Sponsor
Well first if its locking the converter you need to determine why? Is it being commanded? If the PCM is enabling lockup under those conditions then changing the converter would be useless. So have you data logged to see if it is enabling lockup? I know I talked with a guy the other day he has a similar problem at the track. When it shifts to 3rd at wide open throttle it goes into lockup but he did data log and in fact it is being turned on by the PCM hes now trying to find out why and if he lets me know I will post back. with what he came up with.
__________________
FWIW, mine will lock up in third at 25 when the engine is warm and the selector is in "D". From there it pulls fine up to about half throttle, then it will unlock.
Doesn't bog, lug or anything, just pulls up to the speed I want to be at, then I put it up into "OD" and go about my merry way.
I am always in 3rd gear around town and it locks up hardcore at 30 and I give it like half throttle it goes no where it just falls flat on it's face pretty much. I'm also getting 4 degrees of kr too.
I had my tuner reset the values on my converter for knock, and it locks and unlocks fine at the mph I want it to.
Probably your best bet is to do what Frank posted and have the car scanned while it's acting up. See if the PCM is commanding the converter to lock up or not. It shouldn't be letting it lock up at 1/2 throttle at all unless it's tuned to do so.
Again, I'd find someone who tunes, or possibly go to the local transmission shop, they usually have scanners that can see what data is being transmitted to and from the transmission.
How much throttle do you have to give the car before it unlocks in 3rd?
What position is the selector in?
Have you tried it with the selector in both "D" and "OD"?
What brand and size converter?
Do you have it tuned for the converter?
Give a little more info and folks here on the board may be able to help you figure it out.
Thanks guys it's stock everything on it is stock tq converter yadda yadda yadda LOL and I have to floor it to get it to do anything. From a dig things a beast thought.
Still having problems with the bog down I'm also getting kr when it's locked I've tried to tune it out but I doubt I can. I've popped like 4 02 related codes and they all are "to rich this" and "to rich that" I dont suppose I can successfully tune that out with having no cats right?
What did you change on the car recently?
Unless you changed something, anything, then there is most likely a failed component. IE: KR sensor, O2 sensor, etc...
The single most important thing I have learned in well over 20 yrs of diagnosis Driveability concerns is the fact that you must repair the obvious first. In your case that means you must determine why it is reporting KR, probably an exhaust change issue... and you must determine why there are O2 codes. If it is as simple as Tuning, then hire a Professional to do it right the 1st time and be done with it.
There really is no way for us to be able to determine the source of your converter staying locked up at WOT without having the car. We can only make suggestions.
Hope that helps.
g
Hope that helps.
g
no cats straight piped I dunno if it's a knock sensor problem, wouldnt it pop a code if a knock sensor went bad? I believe the 02 codes I'm getting is rich on all banks maybe the 02's are saturated with soot or gas or something. the ones that where after the cat, she does smell like she's running rich at startup my ltft's are like -10.95 or something.
Well, at this point any discussion without a full understanding of the condition would be supposition and speculation. Let's try to work from a position of strength.
Is there a shop in your area that you trust o take a look at it ? ... preferrably a performance shop
g
g
Year there is I'm a driver for advance so that's all I deliever to all day long pretty much with the exception of midas and t/k and such. What do you want me to ask them to do?
