fuel filter connections
I am using a '99 'vette fuel filter/regulator which has two inlets and one outlet. One inlet is centered and a smaller tube, and the other is slightly larger and offset. If I blow on the larger offset inlet tube, it blows goes through, but the other inlet doesn't.
Which filter inlet gets hooked up to the pump pressure line? I assume the other inlet goes back to tank.
