OTVC wires
Old 03-27-2008, 11:20 AM
whammer33024's Avatar
Default OTVC wires
i was wondering if you guys think that's the best route when doing headers. what are the pros of doing it? what all would i need to make it happen? thanks in advance guys!
Old 03-27-2008, 12:02 PM
ss.slp.ls1's Avatar
The main reason for otvc wires i believe is to prevent burned wires. The other pro is that it looks cooler. You can buy a kit and it will take about two hours and your done.
Old 03-27-2008, 12:38 PM
fordeater's Avatar
thunderracing sells a kit, works good and it makes wire changes much eaisier without them being tucked under the manifolds. and if you have headers you will probably want to run otvc to prevent burnt wires.
Old 03-27-2008, 12:41 PM
caldercay's Avatar
What they said The most important reason is to get the wires AWAY
from the primaries.
http://picasaweb.google.com/calder.c...75703425007154
Old 03-27-2008, 01:14 PM
k awesome! so i don't need heat wrap for the plug wires with these correct?
Old 03-27-2008, 01:32 PM
fordeater's Avatar
you shouldnt, i never have ran heat wrap and ive never burned a plug.
