Whats the name of that grease for poly bushings?
Old 03-27-2008, 12:34 PM
fastvert's Avatar
Default Whats the name of that grease for poly bushings?
I cant remember the name of that grease that works really well on poly bushings, can someone help me out? When i installed my new sway bars they came with a small tube of lube but it wasnt nearly enough and now the bushings are creaking really bad when i go over bumps. I tried spraying some WD40 on them since i had it on hand, but it didnt do ****. Still creaking.
Help!
Old 03-27-2008, 01:35 PM
ROCNDAV's Avatar
I've heard WHite Lithium grease works, I've also heard any PTFE based grease, synthetics, basically any non petroleum based grease should work.
THis site talks about a sticky green poly lube, I've never heard of that before:
http://www.polybushings.com/pages/bushinglube.html
On the very top of this link is lube:
http://energysuspension.com/pages/univ2.html
You can find it at Autozone, maybe our sponsors sell this or somethig similar?
3.4camaro's Avatar
Go to autozone and get some Mobil 1 SYNTHETIC grease. It's good stuff. I use it on all my poly bushings.
Old 03-27-2008, 02:36 PM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Like what has been stated previously you need to use a full synthetic grease or we sell the Energy Suspension "Super Grease" in grease gun size cartridges. The Energy stuff is the best but a full synthetic will work fine.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 03-27-2008, 03:55 PM
ROCNDAV's Avatar
Lee do you have a part number for that cartridge?
Old 03-27-2008, 04:26 PM
Rescue Ranger's Avatar
I used Mobil1 on all my poly bushings also. Worked great. Synthetic Grease is at most Pepboys/autozone.
Old 03-27-2008, 04:32 PM
Sure it's part # 19-1751
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old 03-27-2008, 06:33 PM
fastvert's Avatar
Thanks Boys!
Ls1tech to the rescue once again!
Old 03-28-2008, 05:57 AM
leadfoot4's Avatar
I've used a semi-clear, teflon fortified grease called "Super Lube" with good results.
Old 03-28-2008, 11:23 AM
Originally Posted by fastvert
Thanks Boys!
No problem
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old 03-30-2008, 04:16 PM
fastvert's Avatar
Update: I got a jar of Mobil 1 synthetic grease at autozone for $6 and it worked perfectly. I globed it on like mad and now no squeaks! I think the true culprits were the perches where the sway bar mounts to the body. I lubed those up too and im good to go.
Quick Reply: Whats the name of that grease for poly bushings?
