Milled Heads
Old 03-27-2008, 12:50 PM
aerotest's Avatar
Default Milled Heads
I did a couple of searchs and couldn't come up with anything.
If I mill a set of 241 heads a max of .030 will I have intake manifold clearance issues? I have a factory LS6 intake manifold setup.
Thanks,
Old 03-27-2008, 12:52 PM
BIG_MIKE2005's Avatar
No you will not have issues with the manifold. Even though your miling down the combustion chamber to a smaller CC, your head gasket thickness will help eliminate some of the difference & all will be fine.
Old 03-27-2008, 02:28 PM
1BAD02WS6's Avatar
i milled my 241s .030 used stock head gaskets....works fine
Old 03-27-2008, 02:36 PM
GuitsBoy's Avatar
I milled .040 and its still fine. Some people claim that you have issues milling past .050, but I have also heard a couple stories about people milling .060 without intake issues. Sealing is not a problem, but alignment may be.
Old 03-27-2008, 03:59 PM
aerotest's Avatar
Thanks.
I was thinking about milliing .016 and using a Cometic .040 (I have a 2002 which I believe is an MLS @.054) to achive the .030 reduction. This would also get my quench down to .032 which I have read is better and would allow me to back off compression with a larger gasket if necessary. Only issue is those $60 a set MLS head gaskets are looking pretty good.
