Comp 915 vs 918
Old 03-27-2008, 12:55 PM
marovetsm's Avatar
Default Comp 915 vs 918
Whats the difference between the Comp 915's and the 918's? The cam I am going to use has a lift of .563" and RPM's will probably not go above 6500 and was wondering which would be a better choice.
Old 03-27-2008, 02:40 PM
GuitsBoy's Avatar
The 918s are a stiffer spring, and handle up to .600 lift. You could probably get away with either, but for the small price difference, why not go with the stronger 918's. Theyre tried and true.
Old 03-27-2008, 04:07 PM
oneblackTA2000's Avatar
Tried and true my ***. I just went up to the dealership, my car has been up there all day. They have been trying to figure out why my car has been running so wierd. I broke a 918 spring after just 6000 miles.
Old 03-27-2008, 04:14 PM
Stang's Bane's Avatar
Go with either the PAC 1218 or the 1518. Same type of spring but much better quality.
Old 03-27-2008, 04:25 PM
Last C5's Avatar
What he said.
Old 03-27-2008, 04:58 PM
GuitsBoy's Avatar
Well, they did have that bad batch last year... Probably should have mentioned that. However prior to that, and past that, people have been running them for years without problems.
Old 03-27-2008, 05:48 PM
Tom@SpeedInc's Avatar
After talking with Chris at PAC I have total confidence in their product you can find them on our site here
http://www.ls1speed.com/cont.cfm?cid=C0000794
I have a couple sets of the 1518s I can discount if anyones interested
Old 03-27-2008, 08:11 PM
Yeahdoug's Avatar
That's because they were PACs.
Old 03-28-2008, 06:35 AM
Frost's Avatar
Hey Fraser, those PAC1518's, can I use the same locks and retainers from a normal set of 918s on them?
Old 03-28-2008, 07:37 AM
Yeahdoug's Avatar
Yes, you can
Quick Reply: Comp 915 vs 918
