Low Coolant light on but Coolant is full! Why?
Old 03-27-2008, 06:04 PM
badazz769's Avatar
Default Low Coolant light on but Coolant is full! Why?
ok, my low coolant light comes on only like every other time i crank up my car but the radiator and the resivior are both full and it is not leaking anywhere( i have parke and checked the ground and under the hood numerous times) Also, the engine temp is not getting any hotter than normal so im thinking its just a sensor tripping out but jus wanted a 2nd opinion. If anyone has had this happen or knows whats goin on please let me know. thanx
Old 03-27-2008, 06:15 PM
2001NBMZ28's Avatar
It's a common issue - you can try taking it out and cleaning it, replace it, or just unplug it to keep the light off. It's on the radiator a few inches below the cap. Hasn't happened to me because GM finally took them off our cars.
Old 03-27-2008, 06:20 PM
superbee_68's Avatar
yeah, I just unplugged mine because it's not worth spending the money to replace it
Old 03-27-2008, 07:11 PM
lt1 hawk's Avatar
not to insult you, but have you checked it when it was cooled down?
Old 03-27-2008, 07:37 PM
badazz769's Avatar
yes, since t has started happening, ive checked it b4 i get in everytime and its full. no insult taken, thanx for the help
Old 03-27-2008, 08:17 PM
The Guz's Avatar
Its common for dex cool to gum up the contact on the sensor. Remove the sensor and clean it. Then replace it and see if the light goes off. If it does not then the sensor could be bad and need to be replaced.
Quick Reply: Low Coolant light on but Coolant is full! Why?
