Who makes this converter?
That looks like a custom built converter for a th350/400 for use with a motor plate. (mid plate)
You can verify it by putting it up to an LS engine, the pilot will be too long to use on an LS1.
The color and 350SS should come from Dynamic Converters. They are in Stone Park, Ill. We've used them exclusively in our stock applications for years. They have almost no comebacks. As far as the performance units, we don't, or haven't used many as most people want name brands. I cannot attest for the durability or performance. From your picture, it looks like a converter modified to fit an LS1 without the LS1 convex style flywheel, (not flat). I might be wrong. Look at the extension on the nose and tristar plate welded to the old bolt attatchment points. I've seen some of their converters like this. Hope this helps.
Originally Posted by 382ssz28
I found in my book 2 possibilities- DC10SS-12"-350-400: 2100-2400 stall. The other is-DGM3SS10-10"-350-400: 3500-4000 stall. Hope this helps.
Thanks for the help guys.
