Ran a 12.6 @ 111, 2.0 60' on 100 shot now i'm blown....
I have run the time above with catback, lid and 100 shot. Stock bottom end, suspension and rear end on street tires and A4 trans. Now I'm FI with 432rwhp and 415rwtq. I'm dying with anxiety and kept searching for similar setups with no luck on what the car is capable of. Tracks don't open here until the first weekend of April so I can't just go run it.
Anyone have any ideas on cars capability?
If that was your time on a 100 shot then you'll probably run about the same time, uless you hit it with 100 shot in addition to the blower. For your case, I hope I'm wrong. I am just guessing that you were probably making about the same power on the 100 shot. You say you are making 432 rwhp with the blower but I bet you were making close to 432 rwhp with the 100 shot and you were probably making more torque with the nitrous also. 2.0 sixty foot tells me you were probably spinning a little. I don't know much about blower setups but unless you can build boost off the line I don't see you sixty footing much better. I assume you are full weight? Really that power level should be good for mid 11's in a full weight car but if you only went 12.6 on the nitrous then I am thinking you aren't going to go much faster. What is your elevation?
I'm on stock ws6 suspension. My nitrous kit sputtered a lot when I had it so i'm not sure how good the solenoid was. I think until I get a stall i'll probably stay around 2 second 60' times. I think 12.6 @111 on a 100 shot seems a little weak too.
Superman09 Went 12.0x@114 with his custom twins making 420rwhp on a mustang threw an auto with stock converter and also pulled a 1.8x 60' on 18" BFG DR's.
https://ls1tech.com/forums/showthrea...880&highlight=
There is a lot of guys with less hp in the 11's so i'm hoping with a little better 60' I can sneak in there. Here's an EXample:
409rwhp/378rwtq
11.9@116 1.8 60ft Seems to be time/power like this all over this forum.
I'll guess 12.1-12.2 at 114-115 on current tranny set up. Add a converter, suspension, and dr's and be solid 11's easy. I did 12.8's @111 on a half bolt on 6 speed, I don't think your Nitrous kit was doing much of anything. How does the car feel now when accelerating compared to before?
