Cadillac CTS-V - Does any one make a good rear shock?
CTS-V LEE
03-28-2008, 02:39 PM
Im looking for a set of really stiff rear shocks for the v...the stiff shock an lowering springs w bmr stuff should help alot w wheel hop...let me know wat u find
CTSV_510
03-28-2008, 03:37 PM
do you have FE4s or FG2s now?
RangerRob
03-28-2008, 03:40 PM
if you have fe4's you should consider upgrading to FG2s! i'm planning on it in the next month
CTS-V LEE
03-28-2008, 05:26 PM
if you have fe4's you should consider upgrading to FG2s! i'm planning on it in the next monthi have fe4s how much is the fg2? i want a really stiff rear shock
CTSV_510
03-28-2008, 05:33 PM
I have dealer installed FG2s, $1200 option - I hear they're pretty close to that to buy. I think they're quite noticably different from the V I drove with FE4's. Call Luke for a price:
Luke Butler
(703) 647-8670
lbutler@lindsaycadillac.com
CTS-V LEE
03-28-2008, 05:58 PM
Luke Butler
(703) 647-8670
im looking for a cheap stiff non adj shock or adj idc...im gonna expeirment w this set up
NoRice
03-28-2008, 07:50 PM
call Bilstein and get a shock dyno sheet for the stock shocks then they will make up a set revalved the way you want. the cost at the beginning might be high but you can keep sending them back and have them redone for $65 till you get what you are looking for
The Silver V we just built has QA1 shocks on it that the customer had us install. Bob
stkshkr
03-30-2008, 01:04 PM
I'm using the Monroe replacement shock on the rear, cheap and works well.
My rear QA1 would not adjust so I put the Monroes on till I got them repaired.
Haven't put the QA1's back on because of the good results with the Monroes
Gene, I sent my QA1's to a QA1 authorized shop in Indy that rebuilds them. I'll get you the name of the shop if you want it. Bob
stkshkr
03-31-2008, 09:18 AM
Thanks!
Thanks!
Kidwell Race Cars
317 241-7405
288B Gasoline Alley
Indy, 46222
Bob
CTSV_510
04-02-2008, 09:33 PM
Monroes: http://cgi.ebay.com/ebaymotors/MONROE-SHOCKS-STRUTS-CADILLAC-CTS-CTS-V-04-05-06-07_W0QQitemZ200212993376QQcmdZViewItem?hash=item20 0212993376
trukk
04-03-2008, 11:46 AM
Stk,
Aren't you using the monroe's to induce squat for drag racing? I'd expect those monroes wouldn't be what a lot of people are looking for if they want better latteral handling. Please correct me if I'm wrong.
-Chris
