Torque arm bent??? (PICS)
Old 03-28-2008, 08:06 PM
badass99ss's Avatar
Default Torque arm bent??? (PICS)
I have been having a popping sound coming from my 99 camaro 6 speed car when I leave from a stop. Sometimes it doesn't do it, but when it does it's loud. I can feel/hear it the entire length of the car. Again it only does it from a stop, and it feels/sounds fine while driving. Tried the search and read a bunch of threads about the torque arm being bent.
Thanks
Troy
Attached Thumbnails Torque arm bent??? (PICS)-001.jpg   Torque arm bent??? (PICS)-006.jpg   Torque arm bent??? (PICS)-007.jpg   Torque arm bent??? (PICS)-008.jpg   Torque arm bent??? (PICS)-009.jpg
Old 03-28-2008, 08:11 PM
Black02SLPSS's Avatar
Hmm, kinda hard to tell when its on the car. However you could use this as an excust to get a new torque arm?
Old 03-28-2008, 08:20 PM
badass99ss's Avatar
Yep.....notice the BMR banner in my sig
Old 03-28-2008, 08:21 PM
badass99ss's Avatar
Looks to me as if it is twisted?????
Old 03-28-2008, 09:54 PM
lovin myls1's Avatar
Mine looked kinda crappy like that but noise was from broken transmission mount.
Old 03-28-2008, 10:15 PM
badass99ss's Avatar
Ill look into that, that was my second guess....just haven't had time.
Thanks
Troy
Old 03-28-2008, 10:56 PM
SheldonZ28's Avatar
I thought i had a issue with my driveshaft, it sounded like the driveshaft was either whacking off the tq. arm or tranny was trying to escape from my car.
$9 tranny mount later, problem fixed
Old 03-29-2008, 09:52 AM
9000th01ss's Avatar
If the torque arm is bent it will most likely throw the pinion angle off and you'll get a vibration.
It could be a trans mount, torque arm bushing, even an engine mount causing the Y pipe to bang under load.
Old 03-29-2008, 10:34 AM
chupr0kabra's Avatar
Can you be more specific about where the popping sound originates? Is it from the back? The front? Under the driver's seat?
It could be something as simple as a lug nut that isn't torqued down correctly or a LCA bushing that's worn out.
-Mike
Old 03-29-2008, 10:38 AM
Black FormulaLs1's Avatar
check your tranny mount i have been through like 4 of em...
Old 03-29-2008, 11:03 PM
badass99ss's Avatar
Replaced the trans mount today with the Energy Suspension mount. Noise is gone!!! Thanks for the replies.
Troy
Old 03-31-2008, 11:47 AM
Vicious95Z28's Avatar
That's why I did a T/A relocation!
Old 03-31-2008, 05:14 PM
Glad we could point you in the right direction!
