whereto get the tool to release my hyd. cable
Old 03-28-2008, 09:02 PM
darrellk's Avatar
Default whereto get the tool to release my hyd. cable
i about to pull my tranny and need to now were i can get the tool to release my quick connect on my hdy. cable thanks
Old 03-28-2008, 09:11 PM
chuckyt1's Avatar
You can push the white plastic ring in with the flat side of a screwdriver. Should pop right out.
Old 03-28-2008, 09:19 PM
darrellk's Avatar
thanks
Old 03-29-2008, 01:01 AM
2002_Z28_Six_Speed's Avatar
+1 on the small screwdriver. Mine came out easy.
Old 03-29-2008, 01:25 AM
BarneyMobile's Avatar
needle nose pliers works well, helps to push the disconnent in more evenly making it easier for the line to pop out.
Old 03-29-2008, 01:31 AM
greysteel_M6's Avatar
3/4" open end wrench fits it like a charm
Old 03-29-2008, 09:38 AM
Mike94ZLT1's Avatar
If you happen to get the plastic ring pushed in all the way and it still wont come apart, use some pliers and gently twist it. For some reason every time I take mine apart I have to do this. Works every time!
Old 03-29-2008, 11:25 AM
slayer_taunu's Avatar
i usually use two flat blade screwdrivers. but i cant definitley see how a pliers or 3/4" wrench would work well too... all kinda depends on how much you need to wrestle with it. i have seen them get stuck.
Quick Reply: whereto get the tool to release my hyd. cable
