Drag Racing Tech - Weld Wheel 2.0 center sections
K9Kev
03-29-2008, 04:14 AM
Anyone know what to torque the removable centers on the Welds to when you take them off and go to put them back on??
DopeFedZ
03-29-2008, 07:42 AM
The three times I removed my centers for powdercoating I just tightened them as good as I could. Never had any probs with them.
gator's 99TA
03-29-2008, 09:47 AM
i called weld and they told me. i dont remember. i used locktite on each bolt as well.
csjta2
03-29-2008, 10:42 AM
Weld told me 27 ft. lbs
K9Kev
03-29-2008, 11:00 AM
Thanks guys, I appreciate it.:cheers:
jjordan
03-31-2008, 09:18 AM
If you leave the rim shells out in the direct sunlight for an hour or so before hand it helps(they grow slightly and the center fits the flange easier, especially if thee flange has been built up with powdercoat or anodize.) Make sure this flange area is smooth and doesn't have too much paint build-up. Use a dot of red locktite on the threads start the bolts and tighten around the wheel(like a cylinder head) in a star pattern in about three progressive pulls to keep the center from getting cocked, and finish around 26-27 ft. lbs. Don't just throw them in there and hope there OK. Too much riding on them.
DMH Fabrication
03-31-2008, 09:45 AM
I asked the same question on my alumastars:
http://www.ls1tech.com/forums/showthread.php?t=380445&highlight=
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
