Warhawk block vs ls2 sleeved and welding tabs for 2 more bolts
Old 03-29-2008, 10:11 AM
BigRich954RR's Avatar
Default Warhawk block vs ls2 sleeved and welding tabs for 2 more bolts
Thinking about going warhawk block. But what are the other hiding cost of buy this block? What makes it better then a ls2 with darton sleeves and billet mains with welding two tab for the new bolt holes that will match my 6 bolt LSX heads which i would like to use
Old 03-29-2008, 03:33 PM
Screamin_Z's Avatar
what does ur setup look like? depending on what ur planning it could be overkill.
Old 03-29-2008, 03:46 PM
looking for about 1200-1300hp
Old 03-29-2008, 04:46 PM
Screamin_Z's Avatar
IMO go with a warhawk block OR a LSX block is what I would choose. u can't beat the price. I know the LS2 can handle 1,000rwhp but I'd rather have a lil insurance and go with something that is built for that kind of abuse.
Old 03-31-2008, 09:01 AM
Lsx to much weight warhawk i dont like the fact the 2 bolt holes are moved. but a ls2 with these changes should be as good as warhawk right.
Old 03-31-2008, 03:21 PM
got-a-ls1's Avatar
lsx is only at best 100 pounds more but i believe its only 80 lbs more. If it were me i wouldnt care about an extra 80 pounds vs the block being rated for 2500 hp...
Old 03-31-2008, 03:30 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Well the only issue I see is that your looking at either.
Warhawk or LSX block.
The issue I see is Warhawks are just coming out where I havent personally seen any of them have any issues blowing up. There have been cases of LSX based motors blowing up, OR the issues that were supposed to be solve are being solved but then new problems arise. Like from what I have seen with some big shot n2o motors based on the LSX.
Before regular LS1/LS2 blocks lifting the heads, pushing water/coolant, now you got the extra bolt so its clamping better. its clamping so good that the best pistons out there are starting to take the hit and are failing. **just an example that ive seen**
So its basically a unproven block vs a block that has a potential to fail you. Not trying to steer yea away, but definitly do some research, based on the combo you want to run.
Old 03-31-2008, 10:28 PM
KCS
Moderator
KCS's Avatar
Welding on the tabs isn't gonna be as strong as a block with the tabs cast. Welding on the heads, is gonna introduce alot of heat into the head which tends to relax the material, sometimes causing the seats to fall out.
A darton sleeved LS2 with billet caps is gonna cost alot just in labor and machining, add on the expense of welding on the tabs for the 5th and 6th bolt...
You may as well just try to get in line for an LSX block.
I have seen an LSX making over 1500hp torn down and you could see spots, in the main caps and heads even, where they were moving and meterial transfer was happening. But it still made alot of power and sealed just fine.
Just my 2 cents.
Quick Reply: Warhawk block vs ls2 sleeved and welding tabs for 2 more bolts
