T56 Computer in A4 Car
I have most of my parts together to do my A4-T56 swap.
I've done some research here, and see that after the swap, I need to do something with my PCM so the car's computer is not confused by the new trans.
I can get a computer from a '95 T56 car for $75. Can I install this in my car with no issues? Do the computers carry vin data or anything?
I know the other option is a reflash, but swapping a computer out sounds pretty easy to me.
Thanks for any help.
Dave
Dave
Not sure I understand it, though. My car is an A4. I am swapping to a T56, but I know that will throw off the speedo and have driveability issues. I know people get their PCMs reflashed for this.
But I have access to an entire computer from a T56 car of the same year...can I just swap computers?
Maybe I am not explaining my question well?
wrencher
Aaah I mis read it lol. You can put a T56 calibration in it. look at the thread at the top of the forum that is sticky'd for A4 to t56 conversions.
https://ls1tech.com/forums/manual-transmission/200480-m6-a4-a4-m6-conversion-info-requested.html
You have to wire the car for the trans reflash the PCM & then your all set!
https://ls1tech.com/forums/showthread.php?t=200480
I spent a lot of time reading through that conversion sticky already. That's where I learned about the need to reflash the PCM.
Your most recent answer here makes it seem as though I STILL need to reflash the PCM even if I use a T56 computer, correct? That part is confusing me...maybe because I don't fully understand the role of the PCM within the computer of the car...?
I do know about the various wiring chores that must be done for the harness as well.
It might be cheaper to do the reflash. Just pull the comp out when you start the swap and it will be back in a few days. And I don't think they are any driveability issues, just the speedo being way off, but I could be wrong.
Good luck with the swap, I should be starting mine soon
Edit* check out ebay for the pigtails that you will need. They are alot cheaper than GM and are probably made by the same place
Thank you for the info.
I have not checked, but I hope that I have all the pigtails I need. The guy I bought my trans from left the connectors on the T56 with a few inches of wire for each one, to make it easy for the buyer to hook everything up. I'm hoping they are all there.
Dave
Dave
