403 w/ 98mm??
Old 03-29-2008, 12:27 PM
Mr.MartyStone's Avatar
Default 403 w/ 98mm??
Deal came up on a thumper, I don't know if I'm ready to lose the street nature of my car but I'm wanting to be able to run up to my cage cert when I finish it on a small 275 radial.
What rpm would I see positive manifold pressure, or is it a moot point with the right converter? Turbo is a Innovative 98mm with precision 1.06 g-trim housing. 403, Allpro headed, TH400, Hydraulic roller car. Weighs 2950 or so and will probably be looking at 3150 raceweight when finished. Could something like that even be streeted?
I'm also considering twin 70's or 76's as well, but for a deal this good I really don't want to pass it up.
Marty
Old 03-29-2008, 05:02 PM
Shawn @ VA Speed's Avatar
that a/r is way too small for a 408,would work good on something in the 360ci range,would spool up really hard and fast and then run out just as fast.I think you would be much better suited to an 88 or 91 with a 1.32 ar
Old 03-29-2008, 05:04 PM
Only trying to spin to 7000...still way too small? I'll have to look for a 91 floating around...
Marty
Old 03-29-2008, 05:20 PM
it would probably make it to 7000 but would not be making any power,even worse the boost would be hard to control,it would try to spool up hard,on a radial you need to have precise control.
Old 03-29-2008, 06:45 PM
I'm not class racing the car, just a toy mainly. I'll have to keep doing my research.
Marty
Old 03-29-2008, 07:11 PM
Josh@KY-Turbo's Avatar
If your limit is 7000rpm and a Hydr. cam then jump on it if it is a deal. You will be fine.
By 7000rpm you are gonna make more power than you need on those 275 Radials and are gonna have you hands full anyway.
Have fun.
Old 03-30-2008, 12:51 AM
Yeah I am just trying to scare the **** out of myself and have a blast doing it. Thanks for all your help josh
Marty
Old 03-30-2008, 05:07 AM
crashly's Avatar
Marty
marty,
what 76's you going to use?
what configuration?
ash
Old 03-30-2008, 07:33 AM
Probably just TC76's to keep the cost down...I would rather run this 98mm bad mamma jamma though. If Tiago can spool 70's on a 347, 76's should be no problem on a motor this size.
Old 03-30-2008, 12:26 PM
Andy02Z's Avatar
Default tc76's
Tiago is now running tc76's on his 427 and said there is little difference in spool between them and the 70's.
Old 03-30-2008, 01:10 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,098 Likes on 721 Posts
Stock pcm or BS3 or ???
Old 03-30-2008, 01:16 PM
I'll be running a pcm, but by no means stock. My buddy is a computer genius and builds/updates pcm's. Will have almost all the features at less than half the price.
Marty
Quick Reply: 403 w/ 98mm??
