cutting stock springs?
Old 03-29-2008, 07:28 PM
razorclaw99's Avatar
Default cutting stock springs?
Trying to save money and was wondering if i can cut the stock springs shorter to lower the rear a bit. Has anyone done it? Any pros/cons to it?
Old 03-29-2008, 09:31 PM
nevermind. I just researched and saw how the ride smoothness will suck.
Old 03-29-2008, 10:52 PM
Pontiacerator
RevGTO's Avatar
What did you read? A lot of guys are negative on it, but there are plenty who argue from experience that it works well as long as you don't go overboard.
Old 03-30-2008, 12:06 AM
xxcoolrollinxx's Avatar
ive heard good and bad
as long as you dont tourch them you should be okay
maybe get some shocks and a panhard rod
im cutting my springs 1 coil all the way around and seeing how it rides
Old 03-30-2008, 12:44 AM
zach_ws6's Avatar
rides just as good as my pro kit...yea yea, that might not be saying much. but my point is its not as bad as people make it sound.
Old 03-30-2008, 12:48 AM
wg871's Avatar
We cut them in my buddys and it was so bumpy you couldnt have any kind of open drink is his car. It looked sick though.
He left them on there for two days and then ordered real lowering springs.
Old 03-30-2008, 01:23 AM
zlover129's Avatar
cutting springs (correctly) with stock shocks is the same as buying stiffer lowering springs. If done right, with the proper shocks involved, the car can be made to handle very well. I'm very very happy with my setup.
Old 03-30-2008, 12:52 PM
6SSPEED's Avatar
I cut mine last week and it rides fine. It probably doesn't ride as good as maybe a koni or strano setup but to have almost nothing tied up in a lowering job and looks just as good as a pro-kit I would say go for it. I would not cut out anymore than 1 coil max because anything over 1 is asking for trouble.
Old 03-30-2008, 08:13 PM
motown2's Avatar
can someone post some pics of how much they cut off of their spring...and some pics of the stance that is achieved with it. thanks
Old 03-30-2008, 09:34 PM
presto_z's Avatar
you may want to look into the heater hose mod before you cut your springs
https://ls1tech.com/forums/showthrea...ose+mod+heater
https://ls1tech.com/forums/showthrea...ghlight=heater
Old 03-31-2008, 09:50 AM
Hatchetman337's Avatar
Just make sure that if you cut your springs you don't use a torch. Do it with a fine tooth hacksaw and use lots of lubricant so you don't introduce a lot of heat. If you get them hot, it'll change the spring constant and they won't be consistent.
Old 03-31-2008, 09:51 AM
doaberetta's Avatar
Meh, if you're not going to do it right, just heat those springs up and watch the car drop.
Old 03-31-2008, 11:39 AM
Vicious95Z28's Avatar
I cut mine 6 years ago and never looked back. I couldn't tell that the ride was that harsh but I didn't try to make my car look like it belonged in Mini-truck'n either.
Old 03-31-2008, 01:08 PM
ill try the heater hose mod..Is it easy to do?
Quick Reply: cutting stock springs?
