PLX Wideband pinout needed!!!
Old 03-30-2008, 07:01 PM
BADSZ28's Avatar
Exclamation PLX Wideband pinout needed!!!
Hi everyone! I goofed up! I am trying to shorten my wideband cable and noticed after the fact that there is 2 white wires and do not know which goes where. Can someone help me out? Maybe someone has one that can chase the wires and let me know which whites go to which pins on the connectors?
TIA
Old 03-30-2008, 09:19 PM
brokenfly's Avatar
not sure if this helps...one or the other might be analog wb,or nb voltage...
http://www.plxdevices.com/Installati...UsersGuide.pdf
Old 03-31-2008, 08:32 AM
BADSZ28's Avatar
I tried that document. Not detailed enough. Thanks though. I am guessing they are for the heater in the O2 and it does not matter which way they are connected, but I want to be sure. These things are too expensive to take a guess at it.
Old 03-31-2008, 01:14 PM
Derek @ EDO's Avatar
TOP side, Birds eye view of the unplugged connectors.
Old 03-31-2008, 01:17 PM
Actually if you swapped the two whites around all you would notice is a real rich reading at WOT, the whites control the heating of the sensor. If you would notice this simply swap the white wires around..
You cant actually harm the unit itself from mis-wiring the white wires.
I also PM'd you my cell number just incase you had anymore questions.
Derek
Old 03-31-2008, 03:27 PM
BADSZ28's Avatar
Thanks Man! Just to be sure, these are the open ends that go to the mating connector and not the wire ends correct?
Old 03-31-2008, 05:24 PM
correct Brent, open end of the connector.
Not the pigtailed end.
Derek
Old 03-31-2008, 10:06 PM
BADSZ28's Avatar
EDO comes through again! Thanks Man!
Old 03-31-2008, 10:24 PM
anytime man! Glad ya got it all sorted out!
Quick Reply: PLX Wideband pinout needed!!!
