Stereo & Electronics - How to turn off the stock security system?
tals1
07-27-2003, 12:38 PM
How do you turn off the stock security system on a 98 TA?
tals1
07-29-2003, 10:26 AM
I really would like to know...anyone!?
01 ls1 z28 DA BRONX
07-29-2003, 05:26 PM
press the unlock botton?
onehardmaro
08-05-2003, 09:01 AM
Using the unlock button on your remote or manually locking your doors. The power locks activate the sercurity system when used to lock doors when key is out of ignition and door is open.
maddboost
08-07-2003, 12:18 AM
do you want to deactivate your factory alarm all together?
tals1
08-13-2003, 06:15 PM
Ya, how do you deactivate the alarm all togather?
yellowpontiac
08-15-2003, 10:13 AM
i'm having problems with my anti-theft system also. right now i can't even turn on the car. is there anyway to disable it all together. need to start my car quick.
Rhino
08-15-2003, 02:46 PM
Does the security light come on when you're trying to start the car? If so, first of all try cleaning the key, strangely enough this helps quite a bit of the time.
If for some reason the chip reader in the tumbler is out you can wire in a resistor, in line, with the same value as the chip in the key. Although, this method is a little hacked together.
can you expound on your difficulty a little bit?
yellowpontiac
08-18-2003, 06:40 AM
the securtiy light does turn on when i try to start the car. can u elaborate on that hack u talk about.
tals1
08-25-2003, 08:20 PM
the security light is on when I get in the car most of the time...not when I put the key in..it want start and I have to wait about 3 min before it resets...it is ticking me off! How can disable the whole security system??? I'm so tired of this crap!
01badbird
08-20-2005, 09:17 AM
having same problem have you found out anything?
