Stock Fbody LT1 combustion chamber size
Old 03-31-2008, 02:16 AM
94GreenMachine's Avatar
Default Stock Fbody LT1 combustion chamber size
Just looking around a couple boards looking for stock fbody LT1 combustion chamber info and finding conflicting numbers. Heck right here on the Ultimate LT1 newbie faq its listed as 54cc on the basic specs page and then 58cc on the compression ratio page. ??? go figure. Did it change over the years?
Old 03-31-2008, 09:11 AM
Mojave's Avatar
I have also seen it listed at 54 and 58. I *think* it's 58mm, but I'm not sure.
Old 03-31-2008, 09:22 AM
Dave J's Avatar
I am fairly sure its 58cc
Old 03-31-2008, 09:29 AM
the_merv's Avatar
This lists it here as 54cc.. Comparing the LT1 Chamber to the LT4 Chamber..
"Combustion chambers are almost identical with a negligible .4cc increase in volume for the LT4 Combustion chambers at 54.4cc's."
http://www.grandsportregistry.com/lt1vslt4.htm
Old 03-31-2008, 03:46 PM
Mojave's Avatar
There is where I read they were 54.
Old 03-31-2008, 03:50 PM
BattleShip's Avatar
I have a 93 Camaro head and it cc'd to ~54
I think earlier years MAY have been smaller since I also measured one from a later model and it was ~58. BUT since I have no idea if either was shaved who knows.
I have measured a couple iron they were both 64.
Old 03-31-2008, 03:54 PM
the_merv's Avatar
Yea..the big-body cars were lower in Compression.
Old 03-31-2008, 04:35 PM
good to know, thanks.
Old 03-31-2008, 04:46 PM
zigroid's Avatar
my stock sets of heads with a 3-4 thousandths clean up came in at 53.8 and 53.4
Old 04-01-2008, 10:14 PM
r_trigg's Avatar
Default 54cc
My unported heads are 54cc. The ported heads have been opened up a bit and measure about 55.5cc.
I would say 54cc is really close for a stock head.
Old 04-03-2008, 10:42 PM
airflowdevelop's Avatar
I have had probably 6-700 ltx castings on my bench in the last 13 years. Chambers run between 53.2 and 59.2 in factory form. The late 94 early 95 castings seem to be the best. Find someone to put the burret to the task and you will know for sure!
Old 04-03-2008, 11:07 PM
Marc3.4V6's Avatar
Wow, mine were ported to 56cc, that's some good head work!
Quick Reply: Stock Fbody LT1 combustion chamber size
