What do you of my results 2000 camaro
Old 03-31-2008, 02:27 AM
mohammed_k81's Avatar
Default What do you of my results 2000 camaro
Engine Stock bottom end new rebuilt Cam G5X3 Heads Patriot Ls6 stage 2 (2.02/1.57/59cc) Morel Hydraulic Lifters LS1 with Link Bar Setup (92mm FAST Intake and Nick Williams 90mm TB)
Headers Long Flowtech Y pipe With Electric cutout
Gear M6 Stage 3+spec Package with flywheel
Read End Richmond 3.42 Gear Eaton Posi 28 spline unit TA Performance Rear-end Girdle.
On the dyno I made 466 Rwhp and 429 torq
She runs sweet on the road
Old 03-31-2008, 02:32 AM
Screamin_Z's Avatar
very nice numbers. is that corrected and is it on a dynojet or mustang?
Old 03-31-2008, 06:04 AM
It was tuned by my friend on a dynojet. I wanted over 475 Rwhp am going to change my headers to Kocks and get an electric water pump.
Do you think if I use AFR heads there will be any difference
Old 03-31-2008, 06:39 AM
ls1leadfoot's Avatar
"kooks".....
ne ways...those are very nice numbers opf a rebuilt stock bottom end......how much do you estimate in the build so far $$$$
Old 03-31-2008, 07:23 AM
MemphisZ28's Avatar
does your 10 bolt survive? what kinda tires you runnin? Im in the 12 bolt or keep the 10 debate right now with prolly a hair under 400rwhp in a stalled auto
Old 03-31-2008, 07:24 AM
brad8266's Avatar
Originally Posted by mohammed_k81
am going to change my headers to *****
kooks. Good numbers with the mid size cam.
Old 03-31-2008, 09:38 AM
Am running Nitto Tr555 245 50 16 The rear-end is good for now and I would say it cost me around hmmm $6500 or a little more that's everything even tires buts more expensive for me because my parts are ship from the States to the middle east
Old 03-31-2008, 11:39 AM
teke184's Avatar
nice numbers
what are the specs on that cam...
Old 03-31-2008, 09:51 PM
N4cer's Avatar
Originally Posted by teke184
nice numbers
Odd that you can't find that info. You should easily find the specs when you search for "G5X3 AND specs".
Old 04-01-2008, 12:10 AM
234/242 .600/.610 112lsa
Old 04-01-2008, 06:55 AM
teke184's Avatar
so i have to search just so i can comment on the performance of his car?
how bout ya just list them..
anyway...
nice numbers
so that big of a cam, and heads milled to 59cc...did you have to flycut?
Old 04-01-2008, 07:13 AM
Thank you
No need to fly cut
The cam has a really nice idle heavy traffic is not a problem
Old 04-01-2008, 11:39 PM
N4cer's Avatar
How about you get some manners, or just suck my *****, genius.
It's call courtesy. It is proper message board courtesy to search before asking old, repeatedly answered questions. Welcome to that there interweb. Be careful. It's complicated.
Old 04-01-2008, 11:41 PM
N4cer's Avatar
Thank you
No need to fly cut
I agree. I loved my G5X3. And don't forget the ICL on that cam. It's got 4* of advance ground in.
Old 04-01-2008, 11:56 PM
aaron653's Avatar
It is proper message board courtesy to search before starting a new thread in which you ask old, repeatedly answered questions...However, a search is not required when asking the OP a question. Welcome to dat der interwebz. Be cautious. It's an abstruse system.
Old 04-21-2008, 12:54 PM
Moonder's Avatar
Nice numbers Mohammed, how do you rate the spec stage 3+ ? how does the clutch pedal feels like?
Old 04-21-2008, 01:13 PM
DONAIMIAN's Avatar
Not bad numbers in all. Theres deff some more power with better exhaust and a ported intake.
Old 04-21-2008, 01:18 PM
allngn_c5's Avatar
Good job Mo. Haven't heard from you in a bit, was wondering how the car turned out. I bet she feels pretty good at WOT !!!
Old 04-21-2008, 01:21 PM
allngn_c5's Avatar
With all the $$$$ you got wrapped up in your project, why didn't you go with a set of Tony M's Mamofied AFR 205's or TFS 215's ?? Would've made more power then the Patriot LS6 heads. Not knocking Patriot in anyway but results speak for themselves.
