Forced Induction - Coolant problem
View Full Version : Coolant problem
71chevellels1
03-31-2008, 02:00 PM
This is not really FI related, my set up is a ls1 with 6.0 heads ls6 cam and bolt ons t76 turbo. Heads and new gaskets were just put on about 6 months ago but the cars only seen about 10 mins run time and no road time because i got the car running but it was not driveable. Over the weekend i got the car to a drivable state and started to warm it up. Car was in N, well under 200 degrees 170 ish and starts smoking, and it smells like coolant. I check everything and i couldint figure it out so i give it about 25% throttle and under the load more smoke comes out so i turn the car off. I look at the WG witch is dumped into the atmosphere and theres smoke coming out of that so i run my finger in the exit on the wg and theres coolant inside the WG. I check the oil on the car and it looks like the brand new moble 1 i just put into it. I Top off the rad and let it run more after it cools down. I let it get to temp and i gave it a lot of gas and dont see any more coolant coming out. The oil still looks like brand new oil and i let it run for about 5 mins the second time. Is this head gasket failure? I payed for new head gaskets when the motor was built, also i was reading could this of happend because they used
ls1 head gaskets under my 317s? Anyone have an idea of what it could be? Thanks
MECHAM
03-31-2008, 02:05 PM
if it sat that long could be condensation buildup inside the motor....just let it get warm and idle for 10-20 min or so. if you can park the car at an angle so the condensation will drain out the exhaust pipes.
71chevellels1
03-31-2008, 02:11 PM
Oh sorry i wasant clear enough. The motor was built 6 months ago, the cars been running for the last month, ive just started it up for a min or so a few times to check things on doing my swap. The motor is in a chevelle. The day before this happend the car ran for a few mins with no problems.
Old Geezer
03-31-2008, 02:23 PM
If the condensation is "normal", it should not have antifreeze in it...
It's not a good idea to use antifreeze to start a new engine. Start it w/ plain water. Then, if there's problems, you don't have a/f eating on the brgs....:devil:
71chevellels1
03-31-2008, 07:37 PM
Anyone got any ideas?
