TCS Won't work
TCS Won't work
After I did my G5X2 H/C at lgmotorsports, my tcs decides it doesn't want to function. The light next to the speedo is stuck with TCS off, and it won't come on if I hit the control on the dash. Does anyone know why it would do this? I've had LG look at the problem twice, and I'm not sure what they do, but the problem is gone when I pick the car up. However after driving it for a little bit, the problem comes right back. Sometimes an SES light follows. Anyone have any ideas?
Re: TCS Won't work
I would assume all they are doing it clearing the code which makes it functional again rather then solving why the function fails or is resetting the BCM.
Re: TCS Won't work
OK, i checked the sensors on the TB, they were ok. Checked the power wire to the TCS motor, its fine. Checked the ground wire, its fine. I don't think it's related to the TB cuz I just installed a ported one and I had this problem before. Haven't checked the wheel sensors yet. Is there a way to just delete the code with LS1Edit so it wont show up again? And will autotap tell me what the code is without an SES light? Dont have Edit yet, but I might just get it for this since this kind of thing drives me nuts.
