Can you just hone the cylinders and drop new pistons in
I helped a friend drop a used ls2 (about 30K on moter) in nissan 240 . Im guessing its has a cracked piston in 3 cylinder. Can we just hone it out and put a new piston in.
Moderator
He might as well spend the coin and find a forged piston for the .944" pin and replace them. If the piston cracked, and spread metal through out the engine, he is gonna wanna tear down the engine anyways.
GM used to replace the #7 piston in cars that had heavy piston slap. They would replace just that single piston and reuse the rings without a hone.
Personally, Id consider a quick hone, and replace with forged, stock sized slugs.
Like the others said, all bets are off if the cylinder is scratched.
