Question about 5.3 heads?
Old 07-27-2003, 07:55 PM
Firechicken's Avatar
Default Question about 5.3 heads?
Would I loss or gain power buy removing my factory ls1 heads and installing a set of factory 5.3 truck heads? I have a 98 Z28 with a Vig 3200, Macs&ORP, 3" catback, and a lid. Everything else is stock. Are the Valve sizes the same? What about intake and exaust runners, and compression?
Old 07-27-2003, 08:49 PM
someday's Avatar
Default Re: Question about 5.3 heads?
the truck intake valves r only 1.84, so u need 2.00 or 2.02 valves... the compression will be raised about a half a point... TEA makes some nice truck heads at a decent price...
Old 07-28-2003, 11:09 AM
So would I gain or lose power buy just swaping the heads? Or would it be about the same?
Old 07-28-2003, 11:15 AM
Fireball's Avatar
probably lose due to the smaller valve size
Old 07-28-2003, 07:09 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
Might pick up a little at low rpm but overall I think you'd loose a good bit of area under the curve and loose peak hp too.
Old 07-29-2003, 05:52 PM
Thanks for the info!
