Gears & Axles - has anyone went from 3.23 to 3.73 with a 3000 stall conv
Jalbert
07-27-2003, 09:05 PM
is it worth it and will there be an et gain.
BLB02TA
07-28-2003, 01:57 PM
If you can let me know I what you find out, that is what I was planning for my car.
Ragtop 99
07-28-2003, 07:44 PM
Once you have a high stall converter (atleast 2800) and proper shift points, the gains are consistently about .1 and 1 mph on that swap.
4thGENRETARD
07-29-2003, 04:12 AM
Ragtop,
How about 3:73 without TC. I drive my car daily and with the heat here I'm sceptical about changing my TC for fear of tranny damage. I've heard that tranny failure is unavoidable with TC change.
Ragtop 99
07-29-2003, 12:25 PM
sharky:
What you've heard ("I've heard that tranny failure is unavoidable with TC change") is completely false. A mild low STR stall like a SY 3500 or a TCS 3300 with a 2.0 STR when used with a tranny cooler will not significantly increase your risk of failure. Sure, any mod (e.g. lid, catback, or TC) that increase power through the tranny increases the risk of failure due to the extra torque. However a mild converter is not that big a risk.
A 4000 stall with a 2.5 STR is different, IMO. That can really increase the max torque and the duration of high torque. Even still, bolt-on cars with very high stalls still have a pretty good track record of reliability.
Figure .2 and 2 mph from the switch assuming no TC. By the way, your rear is more likely to develop issues (e.g. whine or gear tooth failure) when you swap gears than your tranny is likely to fail from a mild converter swap.
BLB02TA
07-29-2003, 01:44 PM
Is that the 1/4 or 1/8?
Ragtop 99
07-29-2003, 03:48 PM
1/4
Probably see most of the gain in the 1/8th
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
