Weight of aluminum center 9 inch vs. 12 bolt
Is a Moser 9 inch with the aluminum center section still significantly heavier than the 12 bolt rear? Is there any chance it may be around the same or even ligher?
Re: Weight of aluminum center 9 inch vs. 12 bolt
My Moser 9 with all the aluminum goodies still weighed in at 178 lbs. A 12 bolt with spool will weigh in around 160lbs. Throw in about 15 more lbs for a posi.
