Upper tower strut bar PROBLEMS!!
Old 04-01-2008, 10:44 AM
camarostripes96's Avatar
Location: Academy,Tx (home of temple/academy Drag Strip)
Default Upper tower strut bar PROBLEMS!!
Ok I bought this strut bar off a guy and it seems like it wants to fit but the ac line. And low or high side pressure switch is in the way of the passenger strut bolts!! Anyone have this problem before and what do I need to do?
Old 04-01-2008, 11:09 AM
94whtta's Avatar
Take a picture of your problem, i just did mine and didnt have any issues installing it.
Old 04-01-2008, 11:21 AM
LT1MAN's Avatar
i had to persuade mine a little. you can bend them some as long as it doesn't restrict flow or break.
Old 04-01-2008, 01:35 PM
Ok I will have to get pics this eening!! He said it was for an lt1 I wander if it wasn't for a v6 or ls1 and that queer lied to me just to get a sell? Would that matter if it was different? Or if it was for another year?
Old 04-01-2008, 01:40 PM
94Aquaformula's Avatar
It will work the one on my lt1 came off a ls1. Its just a tight fit.
Old 04-01-2008, 02:54 PM
jb442's Avatar
Just like LT1MAN man, I had to bend the A/C lines to clear brace - Hotchkis in my case. The pressure sensor (which is 'T'd into the line) was in the way. If I recall correctly, I actually took the sensor out, bolted the brace in, and put the sensor back - You should be able to do that without leaking refrigerant because there is valve behind the sensor. Hope that helps...
Old 04-01-2008, 03:53 PM
Ok well gotta get my longtubes on first I guess lol
