Generation IV Internal Engine - Just ordered my 408 now I need a cam....
1ORANGEWS6
04-01-2008, 05:45 PM
I just ordered my short block from LME and now I need help picking out a cam for it. I going to top it of with a L92/L76 combo.
Here some spec on the combo
TSP L92s
72 CC Combustion Chamber
.51 head gasket
1 CC dome L92 Wiseco piston
.010 out of the hole
around 11.5-1 CR
I will also be using 1-7/8 headers as well.
RoDan
04-01-2008, 06:24 PM
I'm kind of in the same boat. Not sure what cam to get for my future L92/L76 combo on a 408. One thing I know is that the cam needs minimal overlap it appears to work well with the L92 heads (from what i can tell anyway), as well as be exhaust biased to make up for the OK exhaust flow of the heads. I have also seen cases where cams with quite a bit of overlap work well with the L92 heads...so I'm kind of stuck right now on my decision. As of late though, I have been looking heavily at the Livernoise Stage 2R (or even stg 3, but probably a tad wild for a street setup) cam for L92's. It looks to be exactly what I want as far as specs, but I don't really know anything else about it as far as real world performance goes. Let me know what you decide on! and good luck!
1ORANGEWS6
04-01-2008, 09:35 PM
I see you're from Memphis. I grew up there. Are you on Speed Southest?
Back on track as far as cams I have been thinking about using LG, Synergy, or Patrick G to spec my cam but I wanted to hear from some others opinions.
1ORANGEWS6
04-02-2008, 09:27 PM
No body has opinion on a cam?
RoDan
04-02-2008, 09:53 PM
I don't know what Speed Southwest is, lol. I think I'm gonna have to go custom cam also, but I still like the idea of a cam specifically designed for the L92/LS3 heads. Just for kicks I was checking out the GMPP 08 catalog, and looked at the specs for the Stage 3 hotcam, it has some goofy specs but it is VERY exhaust biased. 233/276 595/595. I saw a video of it in a vette, and it had a strange sounding hit, I don't know if I like the sound or not...
1ORANGEWS6
04-02-2008, 11:04 PM
It's Speed Southeast. It used to be MRS.
Do you have a link to the for that cam? That is a huge split in duration.
1ORANGEWS6
04-14-2008, 11:55 AM
So no one has any cam suggestions?
RoDan
04-14-2008, 01:48 PM
The gmpp cams are int he catalog. here is a link to the pdf of it: http://www.gmperformanceparts.com/Parts/catalog.jsp
99blancoSS
04-14-2008, 04:18 PM
Why not have LME spec it for you?
Blindmelon
04-14-2008, 04:37 PM
http://www.sdparts.com/product/CRA144HR00121/SDPCL92LS7CustomCamshaft22423205850590114.aspx
1ORANGEWS6
04-15-2008, 08:16 AM
I didn't think that LME did a lot with the L92 heads as far cam testing. I'm not saying anything bad about them, so please don't take it that way. Bryan said that he could do cams and other things but building strong short blocks is what he is good at.
1ORANGEWS6
04-15-2008, 08:17 AM
I hoping to go a little bigger if possible.
99blancoSS
04-15-2008, 09:13 AM
10.75-11.25--compresion
242° 0.610" 244° 0.612" 113°+3° XER
Just an example of our custom cams for 408's
venom ws7
04-16-2008, 08:48 PM
Talk to TSP maybe they will spec the best cam for with thire heads.
Old SStroker
04-16-2008, 09:23 PM
What a great idea! They should know better than anyone what it takes to make thier heads produce the big numbers. I wonder why it took so long for someone to suggest this?
Don't most head places also sell cams specifically matched to their heads and your vehicle? If not, why not?
xdanny510x
04-16-2008, 10:27 PM
im running a 230/244/114lsa
marcus769
04-17-2008, 12:17 AM
Futral F15 cam? They're a board sponsor.. I have this cam in my car.. Its sick! How streetable does it have to be? Could use a little more info!
Azrael
04-17-2008, 12:31 AM
Barring a suggestion from Bryan, I would go with a Patrick G custom spec. The results seem to be worth his consult fee.
1ORANGEWS6
04-17-2008, 07:27 AM
It doesn't have to be an all out race car but I would like to make some decent power for the track but I would also like to crusie it around on the weekends. It won't be a DD but I would like to be able to be a DD if I had to. I don't know if I'll go SD or stay with a MAS.
It ill have some 1-7/8 headers / ported L92s / L76 intake / Pulley / EWP(later) / 4L80E (later) /
1ORANGEWS6
04-17-2008, 07:29 AM
Yeah I'm kind of leaning toward Patrick G or Rick at Synergy to do my cam.
Patrick G
04-17-2008, 08:36 AM
To get the best recommendation, you'll need to be very honest in what type of power band you're going to want. Also, what type of intake will you be running? Reason why I ask is lots of people are starting to run the GMPP single plane for the L92 heads with excellent results. That intake manfold will want an earlier intake valve open/close and a slightly later exhaust valve open/close. Nitrous will want an earlier EVO. If nitrous, how much and how often? What do your flow numbers look like at various lifts for I/E? So many questions to be answered. This is why all of the better cam guys use a long questionaire to gather as much info as possible.
99blancoSS
04-17-2008, 10:48 AM
^^^^ Patrick would be a very good person for you take take this up with. He can design a cam for your specific needs. There is nothing better than a cam ground to suite your personal style of driving and requirements.
1ORANGEWS6
04-17-2008, 03:25 PM
I would like to have good power under the curve with some good low and mid range torque for driving on the street. I will mostly use the spray at the track and I'll being a progressive 200 shot. I was think of using the TSP L92s for my head selection and I was hoping someone would have come out with a better intake for these heads by now instead of using the L76. I don't really like the carb style intake though so I guess I'm stuck with the L76 until then.
1ORANGEWS6
04-17-2008, 03:28 PM
You're absolutely right, I have read a many a thread with nothing but good things to say about his cams. I have also read good thing about Rick at Synergy as well that's why I would leaning toward these guys.
99Ls1fever
04-17-2008, 05:48 PM
TSP L92s
.51 head gasket
around 11.5-1 CR
I went with the TSP Texas Giant and dynoed on my 408 in Colorado 531.8 and 481.1:devil:
1ORANGEWS6
04-21-2008, 07:13 AM
You have some really nice numbers but the L92s are harder to cam than the cathedral part heads.
