Nitrous Oxide - Looking for a simple adjust on the fly controler
SY732
04-01-2008, 08:19 PM
Anyone use this one or recomend another?
I need to be able to adjust it without my laptop.
http://nitrousoutlet.com/images.asp?type=product&id=2144
http://nitrousoutlet.com/catalog/product_details.asp?group=26&model=84&dept=11&product_id=2144
SY732
04-02-2008, 10:32 AM
Anyone run this or somthing similar?
Ray@Nitrous Outlet
04-02-2008, 11:08 AM
When you say on the fly....do you mean while driving or just without a laptop?
The unit you have listed works great and is easy to use.
SY732
04-02-2008, 11:33 AM
LOL I was thinking between passes IE on the return road while things are still fresh in my mind.
How do the 4 buttons work?
I want to jet for a 150 shot in the NO plate:
Spray 75-100 down low (at wot) and ramp it up to 150 ASAP
Can I adjust the ramp rate too?
Ray@Nitrous Outlet
04-02-2008, 12:16 PM
you can adjust Start % and ramp time with that controller.
For a non-PC based controller I like this one.
http://www.nitrousoutlet.com/catalog/product_details.asp?group=26&model=84&dept=11&product_id=1539
2 stage, window switch, TPS, Activation, Progressive controller.
The progressive controls, delay, start %, and ramp time
SY732
04-02-2008, 04:43 PM
Why do you like that one better?
I already have your window/wot switch, could I eliminate it?
Ray@Nitrous Outlet
04-02-2008, 05:35 PM
yes it would replace the window switch and integrates everything into one box.
Or you could just add the first unit to the system
caliswangin916
04-02-2008, 11:39 PM
damn.... i would have bought that if i knew about it.
SY732
04-07-2008, 10:52 AM
Am I wrong in thinking I can simply look at the 4 dial controller and adjust anything in 1 second
VS
with the nos I will have to go through all the progaming step by step how long does it take?
Is there any other downside to the 4 dial?
Ray@Nitrous Outlet
04-07-2008, 11:47 AM
correct
not long at all....never timed it when I made changes
SY732
04-07-2008, 12:37 PM
correct
Can you change it while driving? Would you say less than a min or a few mins?
